Vintage Shure V15-type III on VPI Scout?
0 Members and 1 Guest are viewing this topic. Read 1674 times.
milosz
« on: 29 Jul 2011, 12:04 pm »
I recently scored a VPI Scout in an auction for under $1k.  I have a Dynavector 10x5 that I will be using, but I've also got a V15 laying around.... is the mass of the VPI arm too high for the high-compliance V15?  Can it work in the VPI?
neobop
  • BIRD LIVES
Re: Vintage Shure V15-type III on VPI Scout?
« Reply #1 on: 29 Jul 2011, 12:19 pm »
Hi,
Assuming you have the VPI arm, yes it should work.
neo
etcarroll
« Reply #2 on: 29 Jul 2011, 12:46 pm »
Certainly try them both, but know that the folks at VPI are big on Dynavector carts. I got a Scout back a month or so, had a few email exchanges with VPI which had me headed towards the 10x5. Then I also picked up a another VPI higher up the model line instead and went with a DV 20x2-l instead.
Funny, I had an old V-15 with little use I was going to try, but when I pulled it out of storage I found the diamond had come off the stylus, pity. If you do try the Shure I'd be interested in hearing your results.
