FS: Onix Ref 100 Center Channel Rosewood ***SOLD***
0 Members and 1 Guest are viewing this topic. Read 2579 times.
Nick77
« on: 29 Jul 2011, 10:35 am »
****SOLD****
FS: Onix Ref100 Center Channel Rosewood finish in perfect condition, very little usage.
Has 2-5 1/2 Atohm drivers and a vifa tweeter
Also has Sking Ninja No-Rez option installed, $65 value.
Only selling because I no longer own Rosewood main speakers. Originally $850
Asking $275 obo plus shipping. I have original double boxes.
Specs:
System: 2-way dual rear-vented center channel loudspeaker
Drivers: (2) Atohm 5.25″, (1) Vifa XT Concentric Ring Radiator
Crossover: 4th Order
Finish: Birds Eye Maple or Piano Black Lacquer
Frequency Response: 40Hz - 35kHz (+/- 3dB)
Impedance: 4 Ohm
Efficiency: 88 dB (@ 1 Watt / 1 Meter)
Bi-Wire: No
Dimensions: (WxDxH) 22″ x 10.75″ x 8.75″
Weight: 40 lbs. / each
(No Rez is a damping material developed specifically for loudspeaker applications and in particular the functions of damping and eliminating enclosure resonances.
With nearly all loudspeakers there are areas of the enclosure that will resonant while playing. Many speakers allow large unbraced panel areas to be greatly excited and create resonances that are easily heard. Some loudspeakers are well braced and are even made from thicker than average material to minimize resonances, yet enclosure resonances can and will exist.
No Rez is designed to greatly attenuate such resonances using a thick layer of damping material that is treated with PSA. The damping layer of No Rez is nearly twice as thick as that of the popular material shown on the right.
The heavy damping layer of No Rez not only adds mass to the enclosure but it is comprised of a non-resonant material that effectively kills the resonance and greatly quiets the enclosure so that you hear the music and not the box.
The second layer of No Rez is a 1" thick layer of open cell foam, with a textured surface, designed to absorb standing waves and internal reflections in the enclosure.
Many other products used in this application often suspend a barrier layer sandwiched between foam layers. This can have some isolation benefit, but does little to control enclosure resonances.
This isolation layer is typically used in noise control pads to keep sound in some frequency ranges from passing from one side of the barrier to the other. This type of material is typically used in industrial applications to reduce sound produced by noisy machinery. This can sometimes have an adverse effect in some loudspeaker designs if used with a heavy coverage as the suspended layer can mass load the woofer to some extent.
Some material sold for use in loudspeakers incorporate this sound barrier layer with no damper at all. So it has little to no effectiveness in resonance control.
While some of these barrier pads may cost very little, using it in a loudspeaker can often be of very little value other than its effectiveness to absorb internal standing waves with its open cell foam layers. If it has no damping layer then it will not be effective for resonance control.
So mass load your enclosure and not your woofers, and don't settle for less. Get No Rez. It's real resonance control. )
« Last Edit: 11 Nov 2011, 07:05 pm by Nick77 »
Nick77
Re: FS: Onix Ref 100 Center Channel Rosewood
« Reply #1 on: 31 Aug 2011, 02:35 pm »
Bump
Nick77
« Reply #2 on: 27 Sep 2011, 11:10 pm »
Bump....
Nick77
« Reply #3 on: 3 Nov 2011, 10:58 am »
Still available......
goodguy
« Reply #4 on: 3 Nov 2011, 04:53 pm »
I have a AV123 X-CS. How much improvement can I expect in sound quality? Anyone can share your opinion if you had both? Thanks!
