BCD-1 to BDA-1: Best Digital Connection?
0 Members and 1 Guest are viewing this topic. Read 2072 times.
headshrinker2
« on: 28 Jul 2011, 07:03 pm »
Would AES-EBU be a preferred digital connection over coaxial between BCD-1 and BDA-1?
won ton on
Re: BCD-1 to BDA-1: Best Digital Connection?
« Reply #1 on: 28 Jul 2011, 07:26 pm »
yes it would,using a cardas between my bcd-1 and bdac
headshrinker2
« Reply #2 on: 29 Jul 2011, 03:08 am »
Hey won ton on,
Thanks for the reply.  Which Cardas are you using?  How did you arrive at your interconnect?
Deftone
« Reply #3 on: 29 Jul 2011, 12:26 pm »
Tried the spdif but preferred the aes/ebu.Digital cables from Pad's.
headshrinker2
« Reply #4 on: 29 Jul 2011, 12:48 pm »
Purist Audio Design?  Which cable to end up choosing/using?
Thanks.
won ton on
« Reply #5 on: 29 Jul 2011, 12:49 pm »
headshrinker2      well all my other inter and speaker are cardas. just upgraded to balanced cross  inter and speaker. using the only aes/ebu they offer. i've been using cardas for over 20 years
Deftone
« Reply #6 on: 29 Jul 2011, 04:32 pm »
Thanks.
Aquaeaus Aureaus aes/ebu.Venustas xlr i/c and speaker cables.As you know the cables are garden hose size and its easy to work with, not as stiff as you might thought.
headshrinker2
« Reply #7 on: 29 Jul 2011, 06:00 pm »
Thanks very much for the details.  So many flavors of cable out there!
Mind describing your audio system?  And, what cable history/exerience lead you to what you current have?
Deftone
« Reply #8 on: 31 Jul 2011, 03:51 pm »
First of all,you have to listen to this cables yourself to match the system that
you are having.The Pad's cable has a lower noise floor and quieter
 background.Better dynamic, soundstage and clarity.
 I have a few cables that i had use before.Kimber,acoustic zen and aq,ending up with the Pad's which i can say i like most.The system that i am running right now consist of the cd1,da1,bp26 and 4bsst^. Still savinv for the Bit's or Torus 16.
headshrinker2
« Reply #9 on: 31 Jul 2011, 09:54 pm »
Clearly, a home demo is the best way to go when possible.  I read a few interesting articles on the web that compared various digital connection options.  It is common practice for folks on forums to readily recommend AES/EBU as superior.  In the articles I read, coaxial won a few "shoot outs".
