SOLD: REL B1 Sub Bass System - The Most Musical Sub Out There
0 Members and 1 Guest are viewing this topic. Read 2016 times.
adhesiv
I recently acquired a pair of full range speakers to replace my monitors so no longer need the low end assistance the B1 provided. This sub is best described as graceful, powerful, & musical with the ability to extend down to the lowest possible frequencies without breaking a sweat (13Hz!!!!).
Listening to orchestral music you not only hear it but you really "feel" the lower octaves. Many subs are capable of hitting the lowest notes but very few do it as cleanly or as musically as the REL.
I've been using it with the High Pass Speakon connection directly to my Bel Canto amps to cover the lower end sweep that my previous SF Cremona Auditors couldn't quite get down to. The REL with it's unique fine & coarse roll off adjustments were able to blend perfectly with the Auditors while able to disappear into the room when performing. Once I had it dialed in I was never able to separate or localize the sound as coming from either piece...this speaks highly of both the REL, SF, and the synergy the two have together.
One last killer feature I'd like to point out is the ability to run this sub as both .1/LFE for Home Theater AND High-Level Support of your 2 channel system with separate adjustments...No other sub provides this feature and is what makes REL the best choice for a mixed HT/2 Channel system. I only used the High-Level support but I have read many posts/blogs/reviews etc where the primary use was in a mixed system.
Anyway I digress  :D  This REL B1 is in the Black Brittex finish and is in excellent condition. As the unit weighs over 100lbs packed local pickup is preferred (Southern California) but will work with any interested buyers on a shipping option if that's the only option.
Even with the new floorstanders I don't quite feel that the lowest octaves are as right as when I had the REL in the system but space concerns (and budget) dictate reason over lust. This sub was truly enjoyable and will be missed.
Specifications:
Enclosure Type                   Balanced ARM Loaded with Port
Port Diameter:                    4.75 in., 121 mm
Input Connectors:               2-Neutrik Speakon / 2-RCA Phono / 1-XLR
Gain Control Range:             80dB
Amplifier Type:                   DC Coupled MOSFET
Drive Unit:                          12 inch, Long Throw Heavy-Duty Cast Frame
Low Frequency Response:    13Hz In Room at –6dB
Power Output:                  500 Watts
Phase:                              0 and 180 degrees
Dimensions (WHD):          15.25 x 26.5 x 18.5 in. / 388 x 673 x 470 mm
Weight:                          97 lbs., 44 kg
Input Impedance:
100k Ohms, High Level, Two-Channel Unbalanced
100k Ohms, High Level, Single-Channel Balanced
10k Ohms, Low Level (LFE), Black 0dB, Red +12dB
10k Ohms, Low Level, Single Channel Balanced
« Last Edit: 2 Aug 2011, 11:18 pm by adhesiv »
