Shure M97xE mod on diyAudio
0 Members and 1 Guest are viewing this topic. Read 1688 times.
xsb7244
« on: 28 Jul 2011, 02:13 am »
this is old but has anybody read this. google diyAudio Results of M97xE mod.      14 pages of interesting stuff.
so what is the best glue to use for the stylus?  does this mod work?
Wayner
Re: Shure M97xE mod on diyAudio
« Reply #1 on: 28 Jul 2011, 10:34 am »
I owned this cartridge for a while, but it was soooooo boring, I sold it. To be honest, the only mod I'd do to it would be with a hammer. I just couldn't make myself get another one to try the mod.
Wayner
neobop
  • BIRD LIVES
« Reply #2 on: 28 Jul 2011, 01:56 pm »
Hi,
Since that thread was current, Jico came out with an SAS stylus for the M97. That is said to transform the cart and address the deficiency. Loading the stock cart at 62K, if that is a possibility, is also an option. Before you glue the stylus I'd consider a replacement. You can get the SAS at LpGear or directly from Jico in Japan.
neo
felixscerri
« Reply #3 on: 30 Jul 2011, 10:43 am »
G'day all, I'm one who uses the 'stock' M97xE at 62 k and I have no complaints with the upper treble response.
The Jico SAS stylus is a better stylus at 47 k, but the stock version loaded at 62 k is very agreeable sounding.  It is easy to do if you DIY your own phono stages as I do.  Regards, Felix.
