0 Members and 1 Guest are viewing this topic. Read 2761 times.
Set iTunes volume to "Full"Volume settings below "full" may cause severe distortion, especially on version 6 and earlier.The volume controls in iTunes versions 7.X and 8.X will not cause significant distortion. The user should not hesitate to use the volume control in iTunes v7.x and 8.XThis does not refer to the track-specific "Volume Adjustment" settings found in the "Get Info" menu. The "Volume Adjustment" setting should always be set to "None" for all tracks.
When they say 'don't hesitate', that means the sound is unaffected, right?
In some instances I feel that I am hearing excesssive distortions from my audio systems when the ipod/iphone volume is maxed out, so I sometimes lower the volume slider a bit. Then I fine tune the volume with the preamp's control. Is this a bad idea?
It has been my experience that you can cause distortion in Itunes by by pushing the EQ to hard. Watch that preamp setting in the equalizer I set mine at about -3db.
Everything I've seen or heard indicates that all eq/sound enhancer/gain in iTunes should be avoided completely. EQ should be turned off.
