0 Members and 1 Guest are viewing this topic. Read 7250 times.
That is not the correct circuit for the Hafler surround sound. It is this: and here is the instructions: Wayner
Keep in mind that louder always sounds better (until it becomes annoyingly or painfully loud). This is scientifically demonstrated phenomenon. Beware if initial impressions. Boomy bass and zingy highs can be impressive at first. Don’t be surprised that kind of the sound becomes “too much of a good thing” and the exaggerations begin to fatigue (you need a change of venue). Using two sets of speakers can be like chocolate with peanut butter or it can be like honey with garlic. Regardless you’re developing multiple points of sound with the soundwaves produced by each causing multiple interferences, so in theory it can’t be a good thing. As stated above, in-room speaker frequency responses are seldom ideally flat to start with, so adding another set of speakers is a crap shoot.To even out the frequency response it’s best to try matching room to speaker (big room – big speaker, different speaker designs react differently to the room), then room treatments, and finally applying equalization (which only flattens the response in a single location – wherever the microphone was).The best way to audition speakers is: no more than 4 pair per day (listener fatigue makes anything more pointless); use music that you’re familiar with; use a sampling that represents all your favorite sounds; take as long as you like (without distractions); if at all possible try at home where you’ll be listening.
Using two sets of speakers can overload the amp, especially if the impedance drops.
Now you can do lots of preliminary leg work from your keyboard and hopefully find a local club. Start on the internet with reviews of pieces you're familiar with and learn the reviewers so you can "read between the lines" in their other reviews. Some professional reviewers accept e-mail correspondance, which helps a great deal. I have three or four reviewers that I understand/appreciate/agree with. All that is convenient to do but takes lots of time.
