So which combo is better?
0 Members and 1 Guest are viewing this topic. Read 1425 times.
« on: 25 Jul 2011, 11:52 pm »
Digital Sources > DAC > Preamp > amp which would also be analog sources > preamp > amp or
Digital sources > DAC/preamp > amp which would also be analog sources > Phono preamp > DAC/preamp > amp
Which way would you choose? I keep going back and forth as to which one to do. I know a lot of this would depend on the quality of the chosen components. Assume they are all of comparable quality.
HT cOz
Re: So which combo is better?
« Reply #1 on: 26 Jul 2011, 04:42 am »
I would keep the pre-amp seperate from the DAC as the pace of change in the DAC space is too quick to marry the DAC to the Pre. I would consider a good integreated though.
Elizabeth
« Reply #2 on: 26 Jul 2011, 04:57 am »
Agree keep the DAC apart from the preamp.
A lot of folks are moving to integrated amps. Anda lot of good integrated amps are being made now.
(for a long time there were almost none)
Keep the phono prepre separate also from the integrated or preamp/amp
I would say buy lesser used DAC and used phono. a good integrated.
Later you can upgrade the dac and phono. And with having purchased used, you can sell the first ones for about what you paid.
