GR Research N3's $1500.00
0 Members and 1 Guest are viewing this topic. Read 2015 times.
Outofthewoods
  • Fallen Enclosures, Inc. Crafted with Passion
« on: 25 Jul 2011, 02:40 am »
Hi all,
Had a spare set of N3 enclosures lying around collecting dust, so I decided to modify them a little and try out a new design. This is the end result.
The red sections are finished in a Burnt Cherry Pearl and the tweeter plates are done in an Anthracite Pearl. The pearl in the red was impossible for me to capture as it actually is and these pics in no way do it justice. The true color isn't at all as solid as it appears. It's very "pearly".
This pair is being listed @ $1500 fully built and ready to enjoy. :thumb:
Build and finish details:
Premium MDF construction all around.
1.25" thick front baffle.
(3) concealed 3/8" cylindrical Neo magnets per enclosure for grille attachment.
Bases and tops attach via threaded inserts.
Paint job consists of a (2) step prime and seal, followed by a two stage Urethane finish.
The white portion of the finish work is a Premium White Leatherette.
BTW, the drivers are not attached in these pictures. The bottom of each driver hangs out about 1/2" from the face of the baffle.
Ruben
poseidonsvoice
    • 2 channel/7 channel setup
Re: GR Research N3's $1500.00
« Reply #1 on: 25 Jul 2011, 02:44 am »
I would say that with the level of work you have put into it, and the fact that it is a fully built, ready to play GR research N3 - it's a steal:thankyou:
Bravo.
Anand.
Outofthewoods
« Reply #2 on: 30 Jul 2011, 06:32 pm »
Thanks Anand! :D
Ruben
