0 Members and 1 Guest are viewing this topic. Read 6126 times.
Did you have check valves in place for each pump? It may have been fighting the output of the larger pump. Do you have a larger output pipe coming out of the Y. If the pipes are all the same size the pumps may have difficulty pushing the combined water flow.
Did you have check valves in place for each pump? It may have been fighting the output of the larger pump. Do you have a larger output pipe coming out of the Y? If the pipes are all the same size the pumps may have difficulty pushing the combined water flow.
Is the back-up submersed? If not, then overheating will occur since they are not meant to run continuously.
It sounds like your backup pump is now mismatched by your upsized primary pump. You could add a separate parallel discharge pipe if feasible. Otherwise, you ought to have someone evaluate the system to determine needed improvements. At the very least, you need to reconfigure the float switches/control system to keep the pumps from operating in parallel.
After giving this considerable thought, and reading all of the replies, I am going with "too much restriction in the pipe from the other pump" theory. Here's why - the back up pump was professionally installed along with a 1/3 HP primary pump. I later upgraded the 1/3 HP pump to 3/4 HP after the 1/3 HP motor failed to keep up in a major storm. I am guessing that upgrading from 1/3 to 3/4 HP primary pump changes the equation considerably. Make sense?Thanks for all of your replies!
When I first moved into my existing house the downspouts ran right into the foundation. We had a spring-time gully washer and we had water FLOWING in the basement. In on the north, out the door on the south. I brought in two truckloads of dirt and built a retaining wall to get the outside water AWAY from the house. We also routed the downspouts into that 4" black corrugated pipe there were buried so they came out 50' downhill from the house. I also installed a sump pump below the concrete that wasn't that big a deal to install if you know which end of a shovel is the handle . That sump also drains downhill. In the 20 years since I have had one small puddle near the sump, and that was it.Main thing is, block the water at the source if you can, before the sumps take over.
If someone can design a pump that works in a failsafe mode, you will be a fricken millionaire!
