Need help in moving itunes library
0 Members and 1 Guest are viewing this topic. Read 995 times.
borism
« on: 24 Jul 2011, 05:49 pm »
Hi,
I wonder if some Mac experts could help me move my itunes music library from my MBP to an out board Oyen HD. My library has reached 150 GB so I bought a separate 500 GB firewire HD. My plan is to get a new Mac Mini down the road. I use Pure Music and a Tranquility DAC. My computer skills are basic so I would need some detailed info.
Boris
SteveRB
Re: Need help in moving itunes library
« Reply #1 on: 24 Jul 2011, 06:07 pm »
apple has great support pages
http://support.apple.com/kb/ht1449
ted_b
« Reply #2 on: 24 Jul 2011, 06:23 pm »
I just moved mine from an Oyen to a NAS.  This is a great article.
http://www.ilounge.com/index.php/articles/comments/moving-your-itunes-library-to-a-new-hard-drive/
My $.02..
1) basically point it (in preferences, advanced) to the new Oyen drive, empty currently..then
2) consolidate (under file-organize-consolidate) in which itunes copies your files over to the new destination.  Then delete the old ones manually.  This allows itunes library database files (usually housed under users/user/music) to synch up, etc.
It's all in the article
borism
« Reply #3 on: 24 Jul 2011, 07:09 pm »
Thanks for the responses! This seems very detailed, just what I need.
IonMoon
  • The pause is as important as the note
« Reply #4 on: 26 Jul 2011, 09:01 pm »
I just got a new hard drive for my music files. I moved them, then changed the directory in iTunes... it appeared to be transferring the info. But when I look for particular files, they are not in my library (but are on the hd). Very frustrating.
I don't like iTunes generally and prefer Media Monkey- however I want to use my iPad as a controller. Grrr. I would just uninstall and reinstall iTunes, but I have an iPhone synced to it, so I am sure that would cause grief.
Anyhow. I am going to read over the article. Hopefully it will help me out too!
