ALAC format
0 Members and 1 Guest are viewing this topic. Read 1800 times.
mikemalter
  • Have a nice cup of coffee
    • The Computer Mutt Blog a repository of divergent computer knowledge
ALAC format
« on: 24 Jul 2011, 04:01 am »
James, sorry if this question has already been answered, I looked around for it and could not find it.
Does the BDP-1 play ALAC?
Thanks.
Mike
  • The Demo is Everything!
    • http://www.bryston.com
Re: ALAC format
« Reply #1 on: 24 Jul 2011, 11:05 am »
Thanks.
Mike
Hi Mike,
Apple-lossless YES - although I find you can have album art issues because of the way iTunes uses a separate file to store album art.
james
miss_moneypenny
Embedding album art in ALAC
« Reply #2 on: 8 Aug 2011, 09:04 pm »
Just a heads up that album art can still be embedded in apple lossless.
James is quite right that any automatically obtained iTunes artwork may not embed properly as it is a cached resource.
However, there are a couple of ways round this.  One is to rip CDs using X-Lossless Decoder which is an outstanding free app, the other is iTunes.
With X-Lossless Decoder (XLD) - at the point of ripping, the software grabs from the web its "best guess" of the album art.  80% of the time it's spot on, though I am very picky and search for the highest resolution images and resize them to 475 x 475 at 150 dpi.  The resized image can then be dragged onto the main XLD album window to embed into the file.
To embed album artwork into iTunes.  Select an imported album in iTunes, use Command-I (on a Mac) and drag the correct jpg onto the artwork placeholder.  Voila - all the songs in that album are embedded with the artwork.
Hope that helps...
Re: Embedding album art in ALAC
« Reply #3 on: 8 Aug 2011, 10:10 pm »
Hope that helps...
THANKS  :thumb:
 james
