Dimensions
0 Members and 1 Guest are viewing this topic. Read 1200 times.
RLL1
Dimensions
« on: 24 Jul 2011, 02:57 am »
Hi All,
Could someone help me out confirming the height of the BDA-1. The Bryston site indicates heights of 1.75" or 3.125", depending on what document you are reading, and one of the online reviews states it as being 2.75". I have spent the last hour looking at pictures, trying to compare it with the BP26 and MPS-2, which are consistently reported as being 2.25" in height.
BTW....There is a lot of great information here. You almost have me ready to pull the trigger on a complete Bryston setup.
Thanks in advance
  • The Demo is Everything!
    • http://www.bryston.com
Re: Dimensions
« Reply #1 on: 24 Jul 2011, 11:11 am »
Hi All,
Thanks in advance
Hi RLL1
Yes it can be confusing because the PRO faceplates are  1 3/4 inches high with no feet as they mount in a rack and that is the standard height.  The consumer faceplates are 1 half inch taller and when you add the feet you get to 2 3/4
james
RLL1
Re: Dimensions
« Reply #2 on: 24 Jul 2011, 03:16 pm »
Thanks James. Are the 2.25" heights of the BP26 pre amp components PRO or consumer? I realize this must sound crazy, but space is at a premium and I don,t have a lot of flexibility.
Rick
BrysTony
Re: Dimensions
« Reply #3 on: 24 Jul 2011, 03:41 pm »
And just to add -- the BP-26, MPS-2, BDA-1 as well as the BDP-1 are all the same.
Tony
Re: Dimensions
« Reply #4 on: 24 Jul 2011, 03:42 pm »
Rick
Correct all C-Series preamps are the same 2.25 inches
james
