WTB: 5AR4s
0 Members and 1 Guest are viewing this topic. Read 742 times.
jhm731
WTB: 5AR4s
« on: 23 Jul 2011, 05:59 pm »
Looking for a pair of 5AR4 rectifier tubes.
Berndt
Re: WTB: 5AR4s
« Reply #1 on: 23 Jul 2011, 06:21 pm »
Can you sub 5vr4's? I have a handful of g bottles...
Phil A
Re: WTB: 5AR4s
« Reply #2 on: 23 Jul 2011, 06:58 pm »
Location, what you are using them in and budget may help
jhm731
Re: WTB: 5AR4s
« Reply #3 on: 23 Jul 2011, 07:01 pm »
No.
"The 5V4 is certainly not a substitute for the 5AR4 though it will function in some circuits without failure. First, the voltage drop is significantly greater with the 5V4, so your circuit will have to be stable at lower voltage, second it is more fragile than the 5AR4."
I hoping the 5AR4s will give me a bit more power over the 5U4Gs that I'm currently using in a Decware TORII MK III.
