EAT Cool Dampers
0 Members and 1 Guest are viewing this topic. Read 2705 times.
milford3
EAT Cool Dampers
« on: 20 Jul 2011, 06:52 pm »
Came across these while on MOON Audio web site.  Anybody using them?
SteveFord
Re: EAT Cool Dampers
« Reply #1 on: 21 Jul 2011, 12:21 am »
I have something very similar on the tubes in the Sonic Frontiers preamps but each cooler is secured with two O-rings.
R_burke
« Reply #2 on: 21 Jul 2011, 12:56 am »
Is the purpose to keep the tubes cooler - is there a sonic benefit to that?  I use dampers to control microphonics and I BELIEVE it makes a difference, but never heard of cooling a tube for sonic reasons
milford3
« Reply #3 on: 21 Jul 2011, 11:17 am »
The manufacturer claims sonic improvement.  They also claim 10 degrees F lower operating temp. of a tube.  They cost $32.00 a piece.  Do their claims work or is this just another way to take my hard earned money.  Me thinks the latter.
http://www.moon-audio.com/Audio_Vacuum_Tubes.htm
R_burke
« Reply #4 on: 21 Jul 2011, 07:11 pm »
Perhaps they dropped them - the link doesn't lead to anything
milford3
« Reply #5 on: 21 Jul 2011, 07:25 pm »
R_burke
« Reply #6 on: 23 Jul 2011, 02:22 pm »
Try this link:
http://www.tweakshop.com/CoolDampers.html
That worked - thanks, still not convinced to pay the $35 each to "extend" the life of my tubes.  Assuming a 25% increase - that equates to a $140.00 tube.  none of my tubes are that expensive.
decal
« Reply #7 on: 23 Jul 2011, 03:30 pm »
I like my tubes HOT :flame:,the HOTTER :flame: :flame: :flame: the better!!!!!!
milford3
« Reply #8 on: 23 Jul 2011, 05:28 pm »
I concur then.  Save that money for new or (better) tubes.  I'm ordering KT66's now from the Tube Store.   :green:
kingdeezie
« Reply #9 on: 23 Jul 2011, 06:00 pm »
I thought there was a topic a week or so ago that talked about how tubes are supposed to function within a certain temperature to sound their best.
I remember reading that some people who used a cooling fan directly on their tube amplifiers noticed that the sound was worse then without the direct cooling.
If you want to dampen your tubes, obviously Herbie's top of the line dampeners are significantly cheaper, especially if you have a lot of tubes to dampen.
