Chassis fabricator in Perth
0 Members and 1 Guest are viewing this topic. Read 1896 times.
joeling39
« on: 13 Apr 2004, 02:38 am »
Seems that all my sources for chassis fabrication in Malaysia / Singapore has dried up. I will be going to Perth (lived there on & off for the last 15 years) for a short trip soon. Know of any good chassis (sheet metal) fabricators that cater for DIY types (i.e. low quanity, custom job) ? Prefer someone who can do CNC machining.
I am not fussy about materials - can be black anodised aluminum or mirror finish SS (used to get that but no more from the local DIY shop).
Please do recommend. Thanks.
Joe Ling
Rocket
chassis fabricators
« Reply #1 on: 13 Apr 2004, 11:01 am »
Hi Joe,
I live in perth but unfortunately i can't help with a chassis manufacturer.
I built an aksa amp and had the front and top laser cut.  It was fairly expensive to do this.
If you find someone to help please let me know.  i'd be interested.
regards
rod
btw hopefully i'll be in singapore in june for a couple of days and will check out the hifi stores.
bally
    • http://www.kirrabilli.co.nz
« Reply #2 on: 14 Apr 2004, 12:26 am »
Hi Rocket ,
make sure you go to the Adelphi Centre.
Cheers
peter
Jono
    • http://www.yaegeraudio.com
« Reply #3 on: 14 Apr 2004, 04:43 am »
I don't know if I can help, but I just designed and fabricated a chassis especially geared to tube amplifiers.  See www.yaegeraudio.com for details.
TIA,
Jon Yaeger
