Best format to use for ripping CD's to PC
0 Members and 1 Guest are viewing this topic. Read 2570 times.
milford3
« on: 20 Jul 2011, 03:48 pm »
I'm new to the proccess of ripping CD'c onto my computer.  I will be using a USB connected from my PC to my AVR.  Which one of these formats (MP3, MP4, AAC, CD Audio, WMA, Vorbis, FLAC, WavPack, WAV, AIFF, Musepack, Speex, AU, SND) is best to use?  I will be using EAC to rip and the FOOBAR player for playback.  Thanks for any help.
toddbagwell
Re: Best format to use for ripping CD's to PC
« Reply #1 on: 20 Jul 2011, 04:34 pm »
I'd pick either FLAC, AIFF or Apple Lossless.
These are all able to be inter-converted without loss of quality, and have stable and robust metadata support.
Todd
mcgsxr
« Reply #2 on: 20 Jul 2011, 07:48 pm »
If there is any Apple anywhere in your life, use the Apple lossless.
Else, join me with the FLAC!
ajzepp
« Reply #3 on: 21 Jul 2011, 06:24 pm »
I have about 99% of my 7000 tracks ripped in Apple Lossless and they sound great  :thumb:
Noseyears
  • SS-Audio
    • Supreme Sound Audio
« Reply #4 on: 21 Jul 2011, 11:18 pm »
Another vote for Flac...It sounds gr8 :D
timind
  • permanent vacation
« Reply #5 on: 22 Jul 2011, 12:39 am »
I like AIFF which I used with EAC. Only problem I have with EAC is getting the track info to show up.
Thump553
« Reply #6 on: 23 Jul 2011, 12:58 pm »
I think mcgsxr hit it right on the head-unless you have a need for Apple formats, go with FLAC.  Nonproprietary and lossless, fits all my needs perfectly.  Later, if I need mp3s for a portable, it's easy to make them from the FLAC files without destroying them.  Doing it right now, as a matter of fact.
jlafrenz
« Reply #7 on: 23 Jul 2011, 02:55 pm »
If its a PC... FLAC.
Checkout dbpoweramp to rip your CD's.
Dan Driscoll
« Reply #8 on: 28 Jul 2011, 10:19 pm »
Another nod for FLAC and EAC.
etcarroll
« Reply #9 on: 29 Jul 2011, 12:51 am »
If Steve Jobs doesn't own your soul, then FLAC.
mfsoa
« Reply #10 on: 29 Jul 2011, 01:04 am »
Try dbpoweramp before committing to EAC. My db rips sound significantly better than my eac rips.
I use WAV.
-Mike
cityjim
« Reply #11 on: 14 Aug 2011, 08:29 pm »
 For PC usage run EAC to FLAC.
cityjim
