Super 5 in nearfield?
0 Members and 1 Guest are viewing this topic. Read 2711 times.
kgcdc
« on: 19 Jul 2011, 08:05 pm »
Hi,
Is anyone using the Super 5 Monitor in nearfield application? I'm looking for speakers for my desk at work and I can't decide if Super 5 would be overkill in that usage.
Kendall
Hank Murrow
Re: Super 5 in nearfield?
« Reply #1 on: 20 Jul 2011, 12:23 am »
I am using Super 5's in a near near-field setup, in support of both my flat-screen TV and my music system. There are doorways compromising my space as well as the TV, so I listen mostly in a six-foot triangle formed by the Super 5's and me. I find it immediate and yet this arrangement provides a solid stage wider than my speakers, which are 6 feet apart and 7 feet from my head.
I am using all tube electronics(phonostage, Parafeed linestage, and 2A3 Parafeed SET) built by Bottlehead Customs using all-MagneQuest iron and cobalt trannies. You can find my pieces in the gallery section on my page here. I use both an Oppo player and my MacBook Pro as sources in addition to my vinyl rig. Space issues are not important in my setup.
Incidentally, I had Louis build my Super 5's with side-firing ports instead of rear-firing. I find this works well for my setup.
Building T-line subs at present, but if they don't work well enough I will order Louis' Deep Hemps.
Cheers, Hank
Canada Rob
« Reply #2 on: 26 Jul 2011, 04:45 pm »
Sounds like Hank is on the right track with his well thought out system.
If you have the real estate on your desktop the Super 5's would be a good choice.  Also consider the smaller Super 3i.  Just curious, what are you running for an amp, as the amp can have a big impact on the sound?  The 4-1/2" hemp Omegas are very revealing of what is up line from them.
Rob
kgcdc
« Reply #3 on: 27 Jul 2011, 01:21 am »
Amp is Dayens Ampino.
tabrink
  • lake life is good
Re:Hoyt Bedford in nearfield
« Reply #4 on: 31 Jul 2011, 05:16 am »
 Hoyt Bedford Type 1 in near field!
Smurf balls in rear port!
:thumb:
Absolutely the best sound for the money!
Unbelievable in fact!
 :lol:
Money in the bank!
Call Louis today!
Frank I
« Reply #5 on: 31 Jul 2011, 01:16 pm »
Nice setup Tom. I see you could not stay away too long from Omega. LOL Still loving the Super 5 nearfield. Listening to them right now.
