Intermittent music through my laptop
0 Members and 1 Guest are viewing this topic. Read 1257 times.
mjock3
« on: 18 Jul 2011, 10:33 pm »
I am trying to use my lap top as a music server, but the music stops after a while, then plays for 10-20 seconds and stops again. Can anyone help me find out why. I recently downloaded the J. River trial player thinking I would be able to access it for sound but not.
I am using a dell, windows 7, and a hagusb.
Mark
« Last Edit: 19 Jul 2011, 06:23 pm by mjock3 »
srb
Re: Intermittent music through my laptop
« Reply #1 on: 18 Jul 2011, 11:42 pm »
Is the music intermittent if you playback with J. River using the laptop's internal soundcard and speakers instead of USB out through the HagUsb to a DAC?
Doublej
Re: Intermittant music through my laptop
« Reply #2 on: 18 Jul 2011, 11:48 pm »
Perhaps this thread on AA will help. Sound like it might be a buffering or latency issue.
http://www.audioasylum.com/cgi/vt.mpl?f=pcaudio&m=91922
mjock3
« Reply #3 on: 19 Jul 2011, 03:46 pm »
I have since deactivated software running in the background such as a virus scanner, and it seems to be working without a hitch.
Thanks for the feedback. I am very new to all this.
Mark
I guess I was wrong, it is still happening just taking longer to do so. I am trying it through laptop speakers now.
mjock3
« Reply #4 on: 19 Jul 2011, 06:23 pm »
Steve,
Yes it is intermittent, through just the laptops speakers. What does that mean?
I also just turned off wireless connection and Firewall. (I thought I had turned that off.) Will either of these have an impact on my problem?
Mark
mjock3
« Reply #5 on: 20 Jul 2011, 11:35 pm »
Well I believe I have it fixed now. I needed to disable all enhancements on the sound setup, as well as make sure antivirus and firewall are turned off. Forgot to turn off antivirus again this morning and it started again. Shut it off and all is fine.
Mark
