Advice on stop-gap processor and 2ch amp
0 Members and 1 Guest are viewing this topic. Read 1606 times.
Will2
« on: 16 Jul 2011, 12:41 pm »
Hi guys,
Before I get into the details, I'm looking for help pointing me to a great value-for-money stop-gap processor.  Now for the details.
I've got a system that I currently use to watch DVD/BlueRay and my kids play XBox and Wii on.  I have some great components in it (Parasound JC2 preamp - can add the HT-pypass option, Oppo BDP-83 and Pioneer KRP-600M) as I build for a final system for my new house that will be a full 5.1 system but right now I just use it with full-range L&R speakers.  I have a DVDO EDGE in the system acting as a processor (and I guess video enhancer) but it has developed a problem - the DVDO stops sending the video signal to the TV periodically and I need to reset it (by unplugging and replugging it in) about 3 or 4 times in a movie.  Needless to say my better half doesn't tolerate this while I'm away.  So - I'm thinking a stop-gap processor for the next 18 months is the answer.  I say stop-gap because I know how fast processors depreciate and I'd rather wait until the house is done before I buy my LT solution, which will probably be higher end.  My problem is I'm not familiar with processors and if I go on my own I know I'm likely to make a poor purchase.  The only thing I know is I'd like if possible is HDMI out so I only have to run one cable to my TV.
So - if anyone could point me in the direction of an appropriate used processor for sale either here or on AudiogoN - it would be much appreciated.  While I'm at it I'm also open to a receiver or 2ch amp to accompany the processor - but that isn't essential.
Cheers
Will
Phil A
Re: Advice on stop-gap processor and 2ch amp
« Reply #1 on: 16 Jul 2011, 12:55 pm »
This one sold - http://www.audiogon.com/cgi-bin/cls.pl?homeproc&1314831437&/Integra-DTC-9.8-7.1-Multi-chan
I picked one up about 8 months back on my local Craigslist for $600.  They usually go for a bit more so I was lucky.  I was actually so impressed by it (I use it with a 2-channel preamp that has HT bypass), I went a bought a refurb Onkyo 1000 for the secondary basement system on accessories4less.com (that's a good place to look too)
Phil A
« Reply #2 on: 16 Jul 2011, 12:59 pm »
Here's an example if you want a receiver and don't want to spend tons - says they have one left - http://www.accessories4less.com/make-a-store/item/MARSR7001/Marantz-Sr7001-Receiver-Thx-110w-X-7ch-Hdmi/1.html
You can also get an extended warranty through Warrentech through them
Will2
« Reply #3 on: 16 Jul 2011, 01:28 pm »
Thanks Phil - just what I need - specific directions to a specific item for sale that you know would fit my needs well.  I'm going to wait for a day or two to see what some others come up with - hoping that I might get better bang for the buck used - but if not I'll go with your idea, thanks.  I know I'm taking the risk that this last one sells but that's a risk I'll have to take I guess.
Thanks again!
« Reply #4 on: 18 Jul 2011, 01:39 am »
How much did you want to spend? Most of the major manufacturers of AVRs are clearing out last years models at reduced prices. I have seen NewEgg selling Yamaha's at reduced prices. Marantz is also clearing out last years models such as the SR5005 and SR6005, both of which can operate as processors.
Will2
« Reply #5 on: 18 Jul 2011, 01:48 am »
I don't really know but I was expecting to be able to get a high quality older model processor for somewhere around $500-$750.  You think that's a reasonable expectation?
Will2
« Reply #6 on: 18 Jul 2011, 02:05 am »
How would this stack up against the options presented so far?
http://www.audiogon.com/cgi-bin/cls.pl?homeproc&1316061833&/Anthem-AVM-20-huge-price-reduc
srb
« Reply #7 on: 18 Jul 2011, 02:31 am »
Normally I would say that units like this will have far better quality and construction than newer less expensive units, and if you don't need the latest features they can be a great value at < 20% of the original cost.
However, in your case, because
(a) you stated that you would prefer HDMI and these only have component video and
(b) although this Anthem most likely has 2 channel performance superior to newer less expensive processors, you already have a fantastic 2 channel preamp which you are thinking of adding HT Bypass to,
I'm not sure this is your best avenue.  If you didn't want HDMI and were content with component video + audio connections and you didn't have a great 2 channel preamp, then I would say go for it.
Will2
« Reply #8 on: 18 Jul 2011, 02:36 am »
Thanks Steve.  Maybe the best route is to sell the pre and move to something like this.  The pre is way too good for my current needs.
