This must be something new. I had to drill holes in the base of my DWMs to mount them on stands. The midrange/tweeter panels were small enough for me to use Blu-tac to secure them to stands.For whole room applications, the Minis sound incredible but they sound even better with subs and/or an additional DWM woofer that is powered by a separate amp. That should be no surprise since bass from panel speakers in a medium to large room require more surface area and more amp power.IMO the reason why many people love Tympanis and other biamped Maggies is to get significantly more bass without overloading the room with highs and mids that are glorious as is.I guess with the new .7 Maggies that are not easily biamped, one could add several DWM woofers with decent low cost powerful amps. Of course that gets expensive as each separately powered DWM will cost between $1200-2000. If I had only bought the Tympani IVAs. Won't Magnepan consider bringing them back into production as an anniversary special?
Wendell Diller recommends doing just that, using a pair of DWM's to increase the surface area of the Maggies and get a more Tympani-like bass. You can see the right hand DWM is positioned for that in the photo of their listening lab, though it wasn't being used when I was there (at least I hope it wasn't, because the other DWM is lying on the side).<<>>
I am trying to envision my room with 3.7s, 2 DWMs and 2 subs. Seems to me to be an excruciating set up problem. Most likely a pair of 12.7s would do better. Of course if one wanted, adding a pair of DWMs is possible.
Assuming your room is suitable for 3.7s, it should be an easy setup. Just optimize the 3.7 placement and everything else is just gravy or it won't be there at all.The idea of the subs is to provide low frequency extension in the range of 15-40 Hz to the 3.7s. The placement of the DWMs is to provide better, smoother and fast bass and midbass above 40 Hz.IMO the sub bass should be room EQed, while EQ for the DWM may be optional. The 3.7s should only rely on passive room treatments as required.Of course what would be better than this is to just get the 20.7s, though here too a pair of subs for 15-30 Hz would still be a plus.
