0 Members and 1 Guest are viewing this topic. Read 29546 times.
And when I spoke to Vinyl Flat earlier, they also said that some records may take mulitple sessions. IIRC, multiple sessions in the Vinyl Flat were preferable to just extending time in the pouch. May be worth a phone call to them if the documentation doesn't cover this.
I took an unplayable ELP Trilogy and tamed the warp enough to make it playable. My first YouTube post ever.Paul
How about a link PaulDamn you beat me to it
Update: my daughter's Dead Milkmen disc did not become playable after 4.5 hours in the Vinyl Flat. Hard to tell if it is improved much, I did not do before and after videos.Paul
Tried putting the LP in between two pieces of polished plate glass 1/2 " th. Let it sit a couple of weeks and it was flat. Go figure. charlesSMA
Here are some clips of the unit in question. A guy sent me a very warped copy of Aja to experiment on. I tried my usual 8 hours - better, but not good enough. I then tried 12 hours with not much improvement. 24 hours almost had it flat and I then tried the whole weekend at 48 hours with a 12 hour cool down. Take a look at the results. Not perfect but certainly pretty good. Plays quite nicely too.Dave
Now that people have had these a while, do you find the vinyl stays flat after successfully being flattened in the device? Or does it revert back to being warped?
