Will the Cornet 2 work with my amp?
0 Members and 1 Guest are viewing this topic. Read 1293 times.
rublyow
« on: 14 Jul 2011, 05:04 am »
I am considering tackling the Cornet 2 as a first DIY project.  I'm not a huge electronics wiz, so I just wanted to check to make sure that the Cornet will work with my amp.  It's a ~1978 Onkyo A10 integrated.  The (possibly relevant) specs are:
Rated Input: 1.5 volts
Input Impedance: 50 kohms
Line Preamp Sensitivity: 150mV
Line Preamp Impedance: 50 kohms
Like I said, not knowing too much about electronics, I wasn't sure how to mat these to the corresponding Cornet specs.
Any help would be appreciated!
-Dan
hagtech
Re: Will the Cornet 2 work with my amp?
« Reply #1 on: 14 Jul 2011, 07:01 am »
Yes, should be fine.  The real question is what you are using for a cart.
jh
rublyow
« Reply #2 on: 14 Jul 2011, 03:52 pm »
I'm using the Clearaudio Virtuoso Wood MM cart... 3.6mV output.  Is this getting into the low range of what the Cornet can handle?
Biff
« Reply #3 on: 14 Jul 2011, 10:45 pm »
Plenty of output. It will work fine. I've used mine with carts that have nearly half that output.
