0 Members and 1 Guest are viewing this topic. Read 19397 times.
In another thread Seth asked what I wanted in a DAC. It sounds like Virtue is working on a DAC card that will be expansible to multiple types of DACS. What does everybody want to see in a DAC?Here is my suggestion:Digital inputs - 1 USB (24-96k min), 2 digital S/PDIF min (24-192k)--COOL<<<<<Analog inputs - 2 min, with one being a HT bypass--COOL<<<<<Analog outputs - 1 unbalanced variable volume at a minimum, an additional fixed or variable volume unbalanced would be a plusTube bufferVolume control so the DAC can be used as a preamp.--COOL with remote volume control AWESOME<<<<<
Requests for HT bypass, analog inputs, volume control, etc. are basically asking for a preamp with a built-in DAC. But I think that's a preamp, not a DAC. Perhaps Virtue should build a digitally smart preamp, but I really do think that's something different.
... As far as as a DAC goes, I'd want 24/96 in for USB and S/PDIF, with no caveats on the USB performance, and no need to add additional gizmos to get the best performance that the unit can provide.
Antonio,Unbalanced connections use RCA jacks and Balanced connections usually use XLR connectors. Your Sensation uses unbalanced connections.
