How to hook up this Variac
0 Members and 1 Guest are viewing this topic. Read 3978 times.
pelliott321
« on: 13 Jul 2011, 06:37 pm »
Got this at a flee market Good deal if it works $50
Can some one please help me? Just want to make sure I hook mains and load up property so I do not burn the house down
Thanks in advance!!!
So it goes.........
johnhc
Re: How to hook up this Variac
« Reply #1 on: 15 Jul 2011, 01:35 am »
pelliott321, see http://www.fusor.net/board/view.php?bn=fusor_hvpower&key=1207294506 and second reply.  Google is your friend!  Enjoy, John.
« Reply #2 on: 15 Jul 2011, 02:27 am »
After seen the image on this Fusor Link, seems to me the pin 2 and 4 are input.
Pin 1 are output until 20Volts
Pin 3 are output until 100Volts
Pin 5 are output until 120Volts
To be sure better look at the connections of the winding device.
Variacs are nice if it had a big digital display at output for precision adjust level.
I afraid of Variacs with small needle pointer display etc...
Levi
« Reply #3 on: 15 Jul 2011, 02:30 am »
If it doesn't work or you miss wired it...you will end up with a puff of smoke.  Probably get electrocuted.  Be careful that is my point. ;)
So it goes.........
JohnR
« Reply #4 on: 15 Jul 2011, 02:52 am »
Gee whiz  :o They do make them enclosed...
What are using it for?
pelliott321
« Reply #5 on: 18 Jul 2011, 01:38 pm »
I got help over at AA
Its hooked up an working
Varicacs are great to slowly powering up vintage tube equipment. I hook up an amp-meter and slowly raise the voltage watching current draw.  If the current rises very fast there is a fault and you cant cut off voltage before damage is done.  after I make changes or repairs to tube equipment I check the same way, if I made a mistake I can find out with out doing damage.
rollo
  • Rollo Audio Consulting -
« Reply #6 on: 18 Jul 2011, 03:02 pm »
  I have General Radio power supplies for the Loesch & Weisner preamp. Great products from back in the day.
charles
