Power Bar now available without Bybees for $200.00 less!
0 Members and 1 Guest are viewing this topic. Read 2205 times.
Wayne1
I have decided to offer the BOLDER Power Bar AC power strip WITHOUT the Bybee purifiers.
BOLDER Power Bar
This will result in a price of $250.00 for the 6 outlet version and $300.00 for the 8 outlet version.
These power bars are made with custom, 15 amp, ACME AUDIO, silver plated, AC outlets.
All intenal wiring is done in a star configuration with the same 14 awg, Teflon insulated wire used in the NITRO power cables.
Each outlet has its own small filter to isolate any noise generated by any gear plugged into that outlet from affecting the other outlets.
A 3 foot NITRO 14 power cord is hardwired to the Power Bar. The are NO IEC connectors to interfer with the current flow.
The power cord is terminated with a Marinco 15 amp plug.
If you wish the benefit of Bybees, the power bar can be fitted with two of them.
