0 Members and 1 Guest are viewing this topic. Read 20566 times.
This summer I will buy 3 Audio Burson ( or will it be W4S? erghh choices choices) stand alone dacs
I assume the above doesn't matter (using JPlayer, etc.) if you are just sending the digital signal out to a DAC.
Hi-Tried JPlay....How does it sound? Good! Different. Music sounded like it came from a blacker background, with nothing around it. Sort of stark sounding. I could hear some background instruments like cymbals more clearly. Never had the sound as good as this from this Windows machine. But I'm not sure it's "better" or "more accurate" or "more natural" sounding than what I usually listen to.But based on SQ only, I'd be interested in auditioning it more and trying to decide which sound I like best. However, from a POV of convenience, picking tracks to play, switching selections, etc. - it just doesn't cut it. Part of the fun of CA for me is the ability to do just those things. Without that user interface part of the enjoyment of listening is lost. And it's not made up for by a (possible) small improvement in SQ.But the ideas here are clearly worth developing for Windows and other machines. Most minimal processes possible on PC - better sound.
...Then I took the line conditioner out of the system which cleaned the wall socket current and....I was shocked how normal, fuzzy flat and electrolytic the sound became. Now I could not hear the difference between any FM radio broadcasting, Jplay, Pureplayer or just Foobar without any of them
Aleg,I tried Pureplayer, but found it didn't play .aiff files. My entire music library is in .aiff format, so Pureplayer is not suitable for me. The reason I use .aiff files is because they place less processing demands on the system. There is no need for the system to un-compress the files. In addition, I just read somewhere, I think on AC, that some people hear a difference between .aiff files and non-lossy compressed files, such as flac, Apple Lossless, etc. The .aiff files being superior and more natural sounding.Since disk space is so cheap, I don't see any reason to compress for my main music library. By the way, I use a Mercury drive. After researching computer geekdom, that brand of drive was generally considered most reliable, despite published mtbf claims.Best wishes, earplay
