0 Members and 1 Guest are viewing this topic. Read 4449 times.
I suppose this topic is similar to the previous one but instead of adding various devices, I plan to build a second insulated studded wall on the inside of the existing one both for heat insulation and sound absorption qualities.Would this be too much of a good thing? Is it possible to make the room too dead? What kind of insulation would be best? I'd rather not go with fiberglass or mineral wool boards both for expense and lack of local availability. How about cotton? I like that it's clean and non toxic. OTOH just standard fiberglass batts would be the path of least resistance at the price of less absorption.I've also toyed with the idea of integrating diffusion into the wall if I could find some inexpensive ones that are 3-1/2" or less in depth. I'd like to cover the wall with Parts Express speaker cloth, corner to corner.Any comments will be appreciated.-Roy
Russel, It's interesting that you hung the batts or carpet so that they could vibrate for better bass control . BTW nice studio! That wouldn't work for me though because this is an exterior wall and I want some heat insulation. I can see that you've had to contend with a low ceiling too.
