Will 24/96 wav files playback on a CD player?
0 Members and 1 Guest are viewing this topic. Read 1609 times.
DZetye
« on: 7 Jul 2011, 06:44 pm »
I have access to some 24/96 wav files and am trying to figure out how to play them on a CD player.  Do I need to convert them to a different format?
Aleg
Re: Will 24/96 wav files playback on a CD player?
« Reply #1 on: 7 Jul 2011, 06:51 pm »
No, a cd player will only play 44.1kHz/16-bit files.
Those need to be burned to a cd with a burner that can write them in a CD-audio format. It will not work when you write plain 44.1/16 wav files to a disc.
DZetye
« Reply #2 on: 7 Jul 2011, 07:16 pm »
What software will work for this CD rip?
srb
« Reply #3 on: 7 Jul 2011, 07:25 pm »
iTunes can convert your 24/96 file to 16/44.1 and burn an Audio CD.  You don't even need to convert them to 16/44.1 first.  After adding the 24/96 files to the iTunes Library, just drag them into a playlist (required to burn a CD), choose File > Burn Playlist to Disc and make sure that Audio CD is selected as the Disc Format.
