Using a single Crown or QSC amp to power (2) Larger Subs
0 Members and 1 Guest are viewing this topic. Read 1346 times.
zybar
Is anybody out there using a single amp (Crown K1/K2 or QSC PLX3402) to run two Larger subs?
If not either of these amps, what are you using?
George
Marbles
« Reply #1 on: 10 Apr 2004, 08:07 pm »
not exactly..I use a K2 to run to SVS Ultra's.  Highly recommended.
zybar
« Reply #2 on: 10 Apr 2004, 08:21 pm »
Thanks Rob.
I forgot about your setup...
Just curious, how high do you cross them over?
If I remember correctly, you are using the subs just for HT, correct?
George
Marbles
« Reply #3 on: 10 Apr 2004, 08:49 pm »
Correct, just for HT. I currently XO them at 50 Hz.
I have XO them as high as 80 and as low as 40 Hz.
Leave it on all the time as it has a sleep mode.
They are tank like and have a 3 year no questions warranty so have no fear about buying a late model one off ebay.
