JOLIDA JD2A VACUUM TUBE HEADPHONE AMPLIFIER With JD10A ISOLATED POWER SUPPLY UN
0 Members and 1 Guest are viewing this topic. Read 2129 times.
audiowalker
More equipment that I am clearing out. Purchased this set from a fellow Head-Fi member so I think I am the second owner. Units are in excellent condition and work great. SOLD. These also come with the power umbilical cord and power cable. Also, included is a step down transformer in good shape. It has seen better days. No original boxes, though. My thinking is to box each one separately, including the tubes. Then place all into one box. I am not sure what the final weight will be so shipping costs will be at the end when everything is packaged and I know your zip. Shipping will be via UPS or FedEx, insured, with tracking number. Here are the specs from Cattylink.com:
FEATURES:
High-end vacuum tube headphone amplifier.
Isolated power supply unit
Alps volume control
Stunning dynamics with fantastic vacuum tube sound
Detachable power cord (IEC)
TECHNICAL:
JD2A TUBE HEADPHONE AMPLIFIER
FREQUENCY RESPONSE: 15Hz – 20KHz (+/- 1db)
INPUT SENSITIVITY: 700Mw
S/N RATIO: >80 db (NW)
TOTAL HARMONIC DISTORTION: <= 0.4% (1kHz, 100mW)
INPUT IMPEDANCE: 100 kohms
OUTPUT LOAD IMPEDANCE:    32ohms, 320ohms, 600ohms
DIMENSIONS: 250 x 122 x 100mm (W/D/H)
VACUUM TUBES: 12AX7 x 2 + 12AU7 x 2
JD10A POWER SUPPLY UNIT
INPUT VOLTAGE: 220V / 230V +/-10% / 50Hz
OUTPUT VOLTAGE: DC 300V, 50Ma; DC 12.6V, 1A
DIMENSIONS: 240 x 122 x 100mm (W/D/H)
VACUUM TUBES: 6Z4 x 2
POWER CONSUMPTION:  40W
PM for questions. If you would like more pics, just PM. Thanks for your interest. Cheers ~
« Last Edit: 9 Sep 2011, 01:05 am by audiowalker »
audiowalker
Priced reduced. Thanks.
audiowalker
Lower price, thanks.
audiowalker
