V1 tweeter vs Super V tweeter
0 Members and 1 Guest are viewing this topic. Read 1736 times.
« on: 2 Jul 2011, 07:43 pm »
Both of these speakers use 12 inch midranges, but the V1 uses a one inch tweeter, and the Super V uses a 2 inch tweeter.  What are the advantages and disadvantages of each?  Seems like the 1 inch tweeter would beam less at very high frequencies, but on the other hand, it seems like the 2 inch tweeter would be able to cross over lower and have better dynamics and power handling.
Is that correct?  Are there any other considerations when deciding between the 2 kits?
Danny Richie
Re: V1 tweeter vs Super V tweeter
« Reply #1 on: 2 Jul 2011, 08:57 pm »
Both cross at 1kHz and the off axis response follows the shape of the woofer cone. So they are about the same in that regard.
The Super-V tweeter just sounds better, period. The mid-range is better too. It is just a really high end driver with no real expense limitations on the design.
nickd
« Reply #2 on: 2 Jul 2011, 09:08 pm »
I think the the biggest difference is the Super V is machined (opened up) at the back of the tweeter housing creating a true point source OB dipole. the only one of its kind if I am correct. 8)
Danny's on the cutting edge :dance:
ebag4
« Reply #3 on: 2 Jul 2011, 09:46 pm »
The V1's tweeter is opened in the back as well for true OB throughout the speakers range.
Best,
Ed
Rclark
« Reply #4 on: 2 Jul 2011, 10:57 pm »
I'm curious as to why you use a conventional tweeter in the V series as opposed to the Neo planar tweeter. Was it merely the consideration of being able to use a coaxial driver?
nickd
« Reply #5 on: 2 Jul 2011, 11:57 pm »
Good to hear, they used to come with a rear firing dome tweeter. Open back is better.
