0 Members and 1 Guest are viewing this topic. Read 3929 times.
Thanks Brian.It would be nice to see the drivers of each setup, so that I know what I am buying. I know looks aren't everything, but I am one that likes to know exactly what I am getting.I am still looking for comparisons for the standard and megawoofer New Larger. What kind of performance can I expect from each? Will the standard configuration be enough of an upgrade to replace the Epik Legend?The descriptions are a little vague on the VMPS website. Thanks again for your help.
Hello John, thanks for the response.I am by far from being an expert on updating a website, but there is really no need for photographers and professional photo shoots. Just take some simple digital photographs of the drivers and load it into the website.Things being outdated in a few weeks are highly unlikely; in that instance, if I wait a month or two, I will potentially get better drivers. If I recall correctly, driver technology does not change in a matter of weeks, I could be wrong though. It is just confusing to me what I can get, performance wise, for each price point.I am really only interested in the standard and the megawoofer setups as money is an issue. I know you recommend using the 1000 watt amp for the megawoofer setup, what would you recommend to use for the standard setup?Sorry to be a pain in the rear. Thanks for your help.
I am contemplating the same upgrade myself (Ultramegas). I'm also using the AntiMode 8033 and a similar amp (Crown K2).My questions are: A) Is this the best bang for the buck or is it worth it to sell my 2 Larger subs w/megas and just buy the OMG 12" & 15" & BBPR version Largers? Is there going to be that much more difference to justify the extra $$ to buy the TC version? B) Is the cabinet on that OMG Larger version thicker and better braced than my current ones?C) Will I need more amp power to drive it? I can push about 1250 per channel into 2 ohms with the Crown. If that's not enough will a QSC PL380 be sufficient? (short term 4000 wpc @2 ohms)I want an HT sub that can fill (and shake!) my 7000 cu ft open room but is still as musical as my current Largers are. I don't want to spend the money if I'm only going to get a marginal improvement. I'm ready to pull the trigger on an upgrade that will impress the heck out of me. The question is will one of these do that and if so, which one does it for the best value?
