does the se-9 have a fuse?
0 Members and 1 Guest are viewing this topic. Read 1855 times.
superdow
« on: 10 Apr 2004, 02:14 am »
the top of the circuit board isn't readily visable - wondering if it could be located there (assuming that there is a fuse)
superdow
« Reply #1 on: 13 Apr 2004, 09:07 pm »
to answer my own question, no it does not...
superdow
« Reply #2 on: 1 May 2004, 12:15 am »
hey, guess what it does have a fuse. Its located in the plug connection
on the back of the amp. You need to pull out a recessed rubber/plastic piece to access it (use a flat screw driver). :D
