Audio/Video Gear and Systems
The Lab
sts9fan
Pot as fixed resistance: swap for plain resistor?
0 Members and 1 Guest are viewing this topic. Read 1365 times.
James Romeyn
Industry Participant
James Romeyn Music and Audio, LLC
30 Jun 2011, 05:14 pm »
In OEM form my 3-ch amp had small 42k pot wired at input (on the rear panel) for channel level trim.
As suggested by the importer I removed the pot from the circuit. Obviously, removing 42k increased the input impedance significantly above the OEM 24k-Ohm spec.
I suspected the sound might improve by re-connecting the 42k resistance across the input (no wiper) and I was correct. The upgrade was quite huge.
Is there any reason to suspect performance might improve replacing the pot resistance with with a fixed resistor of my preferred variety (Dale)?
*Scotty*
More power for 50 years
Re: Pot as fixed resistance: swap for plain resistor?
30 Jun 2011, 05:57 pm »
I would try a PRP brand resistor,it is just a little bit better than than the Dale. I suspect the pot is a carbon film type and either the Dale or the PRP should have a little lower grain. You could also try a Mills non-inductive resistor as well.
Scotty
The PRPs are available from Parts Connexion
James Romeyn
Reply #2 on:
30 Jun 2011, 06:01 pm »
Thanks, Scotty, especially for the PRP recommendation!
Have you ever heard a difference between a parallel resistance such as described, pot (no wiper) vs. fixed resistor?
*Scotty*
Reply #3 on:
30 Jun 2011, 06:14 pm »
I have not run into a situation like you described but when adjusting the offset out of a differential input via a small trimmer pot I have then replaced it with a fixed resistor to good effect.
Scotty
James Romeyn
Reply #4 on:
30 Jun 2011, 06:23 pm »
Thank you sir!
I shall report results to class later!
The Lab
sts9fan
