Input needed
0 Members and 1 Guest are viewing this topic. Read 1926 times.
Derockster
Input needed
« on: 30 Jun 2011, 12:21 pm »
Hi guys I'm in the market for a phono stage to replace a Linsley Hood that I've been listening to.I'm looking at the Trigon Vanguard11.Any input would be greatly appreciated.Turntable being used is a Rotel rp900 with a Rega rb250 arm fitted with an ADC xlm cartridge
Regards derockster
Minn Mark
Re: Input needed
« Reply #1 on: 30 Jun 2011, 05:56 pm »
The only phono stage I have ever used has been the ones in AVA pre-amps, and have never been tempted to look elsewhere. I suggest you call Audio by Van Alstine and talk to Frank; he has many options from standalone SS and hybrid phono stages, to very economical options for the DIY'er.  I have an Insight pre-amp with Insight phono (built-in) that I use with VPI Classic-Sumiko Blackbird, or a SOTA Comet-Ortofon 2Mred and both rigs sound amazing with his phono stage.
see www.avahifi.com ,  or the AVA circle here.
Mark
BaMorin
  • AR turntable rebuilder/modifyer
Re: Input needed
« Reply #2 on: 30 Jun 2011, 08:53 pm »
Another suggestion would be the DB Systems DB-8 for MM gain (37db) or the DB-8HG for MC gain (52db)
dbsystemsaudio.com        Not a real pretty website. Top shelf equipment for bargain basement prices.
richidoo
Re: Input needed
« Reply #3 on: 30 Jun 2011, 08:59 pm »
Vista Audio Phono 1, $400. Works very well, and well built by an AC Vendor.  I use mine with AT-150MLX cart with excellent results. I can't get enough  of it.
http://www.vista-audio.com/
http://www.audiocircle.com/index.php?topic=69666.0
Derockster
Re: Input needed
« Reply #4 on: 11 Jul 2011, 10:16 pm »
Hi guys,thanks for your input.I've been looking around and stumbled upon the Nighthawk.Any owners out there willing to share their impressions/opinions on this piece.
Regards Derockster
Jlappy
Re: Input needed
« Reply #5 on: 13 Jul 2011, 03:50 am »
Derockster,
sorry no Nighthawk experience.  yet what is the rest of your system? (preamp, etc...).
for what it's worth I had some great luck with the DB Systems DB-8 when i got back into vinyl two years ago, yet have sense up-graded for better symmetry with my preamp/cartridge combo.
cheers,  Jim
Derockster
Re: Input needed
« Reply #6 on: 13 Jul 2011, 08:29 pm »
The rest of my system is as follows,Acoustat panels(model 3s) driven by an Acoustat amp with a legacy High Current preamp.
Regards derockster
Jlappy
Re: Input needed
« Reply #7 on: 14 Jul 2011, 04:16 am »
derockster,
so with the ss pre have you ever thought of a tube phono?  great discussion on Jolida JD-9A phono amp hybrid here on VC.  I was tempted to try a Jolida, yet i have blue circle tube pre amp and ended up picking up a bc phono.   i've seen Jolida JD-9A's going for $300 used or $450.00 new on AudiogoN.
cheers,  jim
Listens2tubes
Re: Input needed
« Reply #8 on: 16 Jul 2011, 08:51 pm »
+1 for the AVA  Insight. :thumb:
95Dyna
Re: Input needed
« Reply #9 on: 16 Jul 2011, 10:24 pm »
Regards Derockster
Hi derockster,
I'm using the Ray Samuels F-117 Nighthawk with my VPI Classic/Benz Micro Wood SL.  I bought them all at the same time so not a good scenario to determine what's contributing what.  I will say this ensemble has blossomed into a exceptional analog playback system.  It took a while to come into its own and I'm going to guess it was the Nighthawk break-in period that made the difference.  I really like the load and gain adjustment knobs on the front of the unit.  Its size lets me place it under the VPI Classic.  Ray Samuels is a great guy to buy from.  He's responsive, treats you as an individual and is very sincere about keeping his customers happy.
When I first started up the sound was a bit bright and in the mid to upper bass there was an annoying resonance.  These are long gone now and I'm just marvelling at how really good the records sound.  I have many recordings that are 30-40 years old and the detail, soundstage and immaging I hear from them I have never before heard.  I say the Nighthawk is a must consideration in the Under $1K price segment.  Ray will give you a 30 day money back guarentee.  Call him and he'll tell you all about it.
Bill
Derockster
Re: Input needed
« Reply #10 on: 18 Jul 2011, 11:38 pm »
Thanks Bill that's all I wanted to hear.
Regards
Cleaton
