SP2- Balanced with Unbalanced
0 Members and 1 Guest are viewing this topic. Read 1119 times.
Mag
« on: 27 Jun 2011, 08:35 pm »
Hi James, thinking of purchasing an SP2.
If I use both balanced and unbalanced outputs won't they have different gain? :scratch:
  • The Demo is Everything!
    • http://www.bryston.com
Re: SP2- Balanced with Unbalanced
« Reply #1 on: 27 Jun 2011, 09:15 pm »
Yes but you can set the gain on the subs independently using their built in volume.
james
Mag
« Reply #2 on: 27 Jun 2011, 10:27 pm »
I wanted to use an extra pair of speaker and a second center channel. Do I just set the gain switch on the amps for these speakers? :?
« Reply #3 on: 27 Jun 2011, 10:40 pm »
Yes if you have Bryston amps that would work as well.
james
Mag
« Reply #4 on: 29 Jun 2011, 04:45 pm »
Will be auditioning the SP2 tomorrow. I know it is class A, I know it has an ultra low noise floor, I know it is liquid smooth. What I want to know is if it retains the full harmonic sound I've gotten use to with my av/receiver in enhanced mode. I suspect that it will but I have to be sure.
Then I have to make the purchase, that's when my knees will start to shake and possibly give out. 8)
