George,> Here's a few <Looking good. You cut and placed the foam panels on the ceiling just right.--Ethan
Joker, Nice avitar but can you use something that is not so pornographic Thanks,
Room treatment is absolutely essential and shouldn't be viewed as one of the last things to do or something to throw a few remaining dollars at.When done right, room treatment has ALWAYS made a significant improvement to the sound of my system.It is enough of a difference that my wife easily notices it! George
John,> Are they for first bounce ceiling reflections? <Yes, they're simply placed on the ceiling in line with the reflection points. George lives only half an hour away from me, so I went to see his setup recently and contibuted what I could. I'm not a fan of foam, but it's okay for mid/high frequencies and he already had some. So I suggested he place them there.> If for first bounce, I would think that having the ridges run parallel with the speaker baffle would be the ideal. <I doubt the ridges really do that much.--Ethan
