0 Members and 1 Guest are viewing this topic. Read 7887 times.
In my house, I ran EMT conduit from the breaker box to a metal box where I have two cryogenically treated, isolated ground outlets. I also ran two independent sets of THHN wires (10 gauge) (each set has hot, neutral, ground), which I had cryogenically treated. Further, I ran a separate ground wire for the metal box (sometimes required to ensure the box remains grounded if the EMT gets separated). Each outlet is on its own 20 amp circuit, although I put them on the same phase.There are codes for the diameter of the conduit based on the size and number of wires running in the conduit. I went one diameter larger. I had everything inspected. Theoretically, the tubing and metal box (and I also used a metal plate for the cover) should be a Faraday shield. As for your other questions, I can't answer them. For instance, I can't see where two grounds for a single outlet would be useful.
Just to clarify, you ran two sets of THHN wire, each set containg hot/neutral/ground, plus an additional ground for the box for a totol of seven wires, each outlet/circuit having its own hot/neutral/isolated ground, plus a ground wire for the box. If I am reading this corectly, you had 3 ground wires, right? Did you run the ground wire for the metal box inside the conduit? Did you bond the EMT at the box and the panel? Did you twist the hot/neutrals but not the grounds, or did you twist the sets of three together and run the box ground untwisted?
...am currently using a paralell power filter (Audience) in conjunction with a whole-house surge protector/filter (Environmental Potentials EP-2050)....
Nice kit, but the Audience Adept power conditioners are not parallel power filters, rather they are series inductance [toroidal common mode choke(s)], parallel capacitance (2nd order lowpass) filters. Any filter that provides isolation contains a series impedance element.FWIW,Paul
...Yep, I have tried an isolation transformer (Topaz) and power regenerator (PS Audio) and am currently using a paralell power filter (Audience) in conjunction with a whole-house surge protector/filter (Environmental Potentials EP-2050). All have made nice improvements to the sound, but none have taken care of the brittlle and sibilant high end I am experiencing. Something that, after considerable troubleshooting, I am chalking up to airborne RFI effecting either the equipment itself or coming through the AC wiring or both.
Well made powercords help, conditioners, shielded cables, and internal filtration/decoupling.
It's interesting that some people spend thousands of dollars on power conditioning, but use cheap ICs and power cords, then expect their systems to have a completely black background. I don't know if that's case here, but just making the point that power conditioning is one part of a "power management" system which includes the "power lines" (ICs, power cords, and speaker cables). In fact, IMO, the foundation of a two-channel audio system is power management, not an amp, source or speakers.
I wouldn't be an audiophile if I didn't have power conditioning.
