Rythmik vs. Rel
0 Members and 1 Guest are viewing this topic. Read 16648 times.
rw@cn
Re: Rythmik vs. Rel
« Reply #20 on: 28 Jun 2011, 10:40 am »
I have heard TBI speakers in a few systems. They are nice.
I.Greyhound Fan
Re: Rythmik vs. Rel
« Reply #21 on: 28 Jun 2011, 05:04 pm »
For the money, I would go with the Rythmik F12SE.
doug s.
  • makin' music
Re: Rythmik vs. Rel
« Reply #22 on: 30 Jun 2011, 04:06 am »
whatever you decide, get two.  it may be counter-intuitive, but even in a small room - especially in a small room, imo - having two subs will help smooth out response, and you will have added benefit of lower distortion at any wolume level...
doug s.
Re: Rythmik vs. Rel
« Reply #23 on: 30 Jun 2011, 05:03 am »
Disagree with that Doug.  If you go with an OB sub, do one, because the idea is to minimize room interaction.  On the other hand, if you go boxed subs, then 2 (or more) is the way to go.
doug s.
  • makin' music
Re: Rythmik vs. Rel
« Reply #24 on: 30 Jun 2011, 02:22 pm »
tyson, even an ob sub interacts w/the room.  having more than one will still smooth out the overall frequency response in the room.
doug s.
