FOR SALE: Bryston/Torus CS15 Power Conditioner $1300
0 Members and 1 Guest are viewing this topic. Read 1191 times.
VOLKS
CS15........$1300+shipping.........Classic Series Power Conditioners for Audio/Video
15AMP Units
Only 1.5 years old in excellent shape.Includes orginal Box/Manual/Recipt.
CS 15
•Plug into standard household outlets
•Provide Clean AC Power and Surge Suppression that really works
•Available in 2 styles - Rack Mount & CS (Silver or Black)
Torus RM15 and CS15 Power Conditioners
These models are 15 Amp compact components with 10 outlets, enabling all system audio/video components to be connected easily. With an elegant brushed aluminum face plate; these components complement any high end audio/video installation.
Technical Specification
Input Voltage and Frequency:120VAC Range ± 10% (57-63)Hz
Input Current Limiting: 16A Circuit Breaker Front Panel
Input (inlet) connector Rear panel: 15A inlet
Line Cord (included): 15 Amp (Type A)
Input current rating: 12A
Output voltage: 120V AC<
Output Current Limiting: N/A
Output connector: Medical Grade Duplex 15A (Qty 5) 10 Outlets
Surge Suppression: Meets IEEE C62.41-1991: Series mode type; built to withstand 6000 volts, 3000 amps for 1000 repeats; with clamping voltage of 2 volts above peak nominal voltage.
Noise Reduction: Performs as low pass filter, attenuating noise from 2kHz to 1mHz, with attenuation of 12 db/decade to 500 kHz.
Weight: 41.9lbs (19Kg)
VOLKS
Re: FOR SALE: Bryston/Torus CS15 Power Conditioner $1300
« Reply #1 on: 12 Sep 2011, 06:33 pm »
bump
