Monolithic PS-1 moded units needs help, ask here or CI?
0 Members and 1 Guest are viewing this topic. Read 1796 times.
Doug Kim
Hi
I bought ModWright moded PS-1 as a used unit, have been using it happily for about an year (the sound is incredible), but one channel suddenly started to cause trouble. I can't describe the symptom exactly, but will try. The sound it produces is very small (almost unheard), but it seems there is a DC offset floating. Irregular hissing and ziggling sound occurs. The other channel is fine.
Do I have to get service from ModWright or Channel Island audio?
I hope it's just a trivial problem.
Doug
modwright
    • ModWright Instruments
PS-1 Mods
« Reply #1 on: 13 Apr 2004, 07:08 pm »
If we modified it then by all means, please contact us directly and I will personally take care of it for you.
Dan W.
