0 Members and 1 Guest are viewing this topic. Read 15781 times.
Well, it is neither cheap nor cheerful at this point ...
The only point I was trying to make is that you can get zone functionality on the cheap with ATV2 (which is what I have). My guess is Sonos does it better, but it is disingenuous to rig the argument so that the two options come out costing the same, especially since the $100 ATV2 provides the analogous functionality to the $350 ZP90, and there is no need for the $100 zone bridge.
the Sonos has a built-in DAC and the Apple TV does not.
My understanding is [ATV2]that its optical output is limited to 48KHz maximum but will pass 44.1KHz redbook untouched, if of course you are bypassing any computer resampling such as the Windows Mixer on the Windows platform.
My understanding is that its [Apple TV] optical output is limited to 48KHz maximum but will pass 44.1KHz redbook untouched, if of course you are bypassing any computer resampling such as the Windows Mixer on the Windows platform.
It converts 44.1k material to 48 kHz (unless it has a setting that I missed when I set it up).
But for some reason the new Apple TV does upsample everything to 48KHz, which is somewhat unfortunate for audiophiles.
How do you get your music into a Sonos server?
Apparently the old Apple TV did not upsample 44.1KHz files to 48Khz. The Airport Express is also bit perfect with 44.1KHz files.But for some reason the new Apple TV does upsample everything to 48KHz, which is somewhat unfortunate for audiophiles.
Why do you say that - have you tested it? (Edit: just seems odd to me to focus in on one aspect of what is after all a very inexpensive gadget)
I think the reason is most video soundtracks are 48kHz, not 41kHz. It may be that it handles both. I got my info from the same CA source, so it might be worth double-checking. In any case, I don't notice a negative impact.Ironically, EDS_ comments have made me more interested in checking out Sonos.
