Sold: Metric Halo ADC/DAC
0 Members and 1 Guest are viewing this topic. Read 1536 times.
omasciarotte
« on: 18 Jun 2011, 02:00 am »
Metric Halo/Sonic Studio Model 302 — Lists for $2895, selling for $1495
The Model 302 is the perfect, 2 channel complement to Fidelia, Pure Vinyl or Amarra. Same as Metric Halo's ULN-2 2d Expanded but includes an additional +DSP software license. This is the next generation, improved version of the 2882 hardware that John Atkinson uses for his location recordings. Use as a great DAC and headphone amp or, use it to digitize your analog library.
Features:
  • 2 Mic/Line/Instrument analog inputs on Neutrik Combo connectors
  • Balanced TRS analog sends & returns for analog inputs
  • 2 analog outputs on balanced TRS connectors
  • 24 bit/96 kHz converters on all channels
  • Headphone amp with front panel volume knob
  • Records 96k/24 AIFF, ALAC & BWF with full metadata
  • Balanced stereo master control room monitor output with front panel volume control
  • AES-S/PDIF Digital I/O with selectable hardware SRC
  • 8 channels of ADAT I/O, switchable to AES-3 TOSLINK support
  • Includes Metric Halo's unique instantiable +DSP processing
  • 4 pin XLR port is ready for off-the-shelf battery power
  • 10 front panel preset system/routing memories for stand-alone operation, no host Mac needed
  • Ultra-low noise preamps for room correction, analog capture, etc.
  • De-RIAA EQ built in for pure digital vinyl conversion & archiving
  • FireWire connectivity frees up a USB port
  • Compact & light weight - 13.75" x 1.75" x 8.5", 1 lb
  • Total recall with Sonic Console
  • OS X drivers with 10.6 support
  • In-line power supply included or use bus power from your Mac
Includes Sonic EQ:
The Model 302’s firmware enables the famous Sonic EQ in hardware. Sixteen topologies, real-time graphing with multiple instances. This amazing sounding equalization is Dr. Keith Johnson's (the engineer of Reference Recordings) favorite. Set up your own EQ presets and recall them at any time…
You don't have to be afraid of EQ any more. :wink: For a pic of the EQ in action, with a minimal phase RIAA de-emphasis filter engaged, see below…
Sonic Console:
Sonic Console is a fully configurable soft mixer for routing, mixing, and live monitoring with near-zero latency. You can “build your own” mixer from scratch or, recall a pre-defined mixer from the library. Each strip includes Metric Halo’s Character, for highly natural emulation of tube and transistor circuits past and present…You don’t need to use Console for day-to-day listening but, it opens up a world of possibilities.
Terms:
Item located in San Francisco…Accepting Paypal gift, USPS money order, or FedEx COD. Regular paypal add 1.5%. Buyer pays shipping and insurance, will be packed & shipped via FedEx Ground unless otherwise requested. For sales outside the US, must be COD.
« Last Edit: 22 Sep 2014, 12:32 am by omasciarotte »
