0 Members and 1 Guest are viewing this topic. Read 6568 times.
the cat pre-amp is not neutral in it's sound. it is lean and forward sounding.r.
on the CAT pre-amp not all tubes are going to make a difference. it is just not the tubes.
But if you want to make blanket assertions about gear, that's fine.
I'll make all the blanket statements I want. Fleece is warmer than down, silken fabrics are over-rated, quilting rocks the shit out of crocheting. And so on and so forth.
Shouldn't we try to find out from the OP what they consider Great Tube Sound?
Each and every tube in the CAT has a significant impact on its stage, even the terminal cathode followers, although to a a lesser extent than the SRPPs. Your assertion that is a reflection of whatever experience you might have with the CAT. I've heard 4 other systems locally with CAT preamps, and none of those systems could be characterized as either thin or forward. A fellow CAT owner characterized my system (when the CAT was my only piece of tubed gear) as warm and laid back.But if you want to make blanket assertions about gear, that's fine.
