soldering iron?
0 Members and 1 Guest are viewing this topic. Read 1357 times.
Rclark
soldering iron?
« on: 15 Jun 2011, 08:21 pm »
I'm gonna be building crossovers on Sunday for an insignia ugrade.
Which of these should I get? The cheaper one is 25 watts. Sorry for the bad pic.
Also what should I do for insulation to wrap around the crossover? Hone depot only has big bales of the stuff.
Thanks fellas
corndog71
  • Some people call me Rob.
Re: soldering iron?
« Reply #1 on: 15 Jun 2011, 08:26 pm »
I would recommend at least a 30 watt iron or preferably a 40 watt iron.  The latter will be much better and faster when dealing with 16 awg solid core wire.
jparkhur
Re: soldering iron?
« Reply #2 on: 15 Jun 2011, 08:52 pm »
Radio shack has some good variable power ones for 25 dollars or less, includes stand and tips
Danny Richie
Re: soldering iron?
« Reply #3 on: 15 Jun 2011, 09:02 pm »
This one has been my favorite: http://www.sears.com/shc/s/p_10153_12605_00927320000P
And I don't have to buy tips for it. It heats up fast too. And I like the light.  :thumb:
Rclark
Re: soldering iron?
« Reply #4 on: 15 Jun 2011, 09:21 pm »
Ok ok, nice.
But what about insulation? I didn't ask at Home Depot but I wonder if maybe I can buy a small bag of insualtion material.
Can I use like, cotton as a substutute for the crossover wadding?
Danny Richie
Re: soldering iron?
« Reply #5 on: 15 Jun 2011, 09:35 pm »
Those are pretty small speakers. Plus your upgrade kit came with 1/3rd of a sheet of No Rez. So you won't need much. You used to could buy a little bag of poly fill at Walmart for about $1.99.
Rclark
Re: soldering iron?
« Reply #6 on: 15 Jun 2011, 09:38 pm »
Ok Danny, thanks :D This'll be a blast.
