FS - EVS 500M Monoblocks (ICEPOWER) SOLD!
0 Members and 1 Guest are viewing this topic. Read 2592 times.
Sonny
« on: 13 Jun 2011, 08:21 pm »
Sadly, I am off loading these wonderful AMPS from EVS (RIC SCHULTZ) using the ICEPOWER using 1000ASP modules.  I am now going to CLASS A (PASS X250) and need to fund the purchase.  Single Ended input only
I paid $2200 for these.
Asking $SOLD$
Here's what Ric says:
The EVS500M is our super high powered ICEpower® mono block amps.  These amps use ®ICEpowers most powerful and best module (the 1000ASP) that puts out over 550 watts into 8 ohms and over 1100 watts into 4 ohms.  These amps will redefine value in high powered amps. The mono block chassis are 8 inches wide, 12 inches deep and 3 inches tall. They use the same feet, input jacks and binding post bypass system as described above. A pair of them can easily sit next to each other on a shelf.  The amps weigh 7.5lbs. each.
« Last Edit: 16 Jun 2011, 11:11 am by Sonny »
Berndt
Re: FS - EVS 500M Monoblocks (ICEPOWER) Asking $1450
« Reply #1 on: 14 Jun 2011, 10:35 pm »
Good luck Tuan.
I think you are meant to have the 250.5.
Bumpage.
Sonny
« Reply #2 on: 14 Jun 2011, 10:37 pm »
Good luck Tuan.
Bumpage.
Bill, I didn't get the 250.5, I can't afford it, I got the 250.
T
mhconley
« Reply #3 on: 15 Jun 2011, 01:22 pm »
These are a great deal people!  I just finished a DIY pair of B&O ICEpower 1000ASP based monoblocks and the parts alone were more than $1450.  I absolutely love the way they sound.  Someone should jump on these...
Martin
Sonny
« Reply #4 on: 15 Jun 2011, 05:36 pm »
Martin
Thanks Martin...These are great amps and Ric Schultz always mods / tweaks stuff to sound better...So, I hope someone grab these...or else I'll have to keep them!   :duh:
Sonny
« Reply #5 on: 16 Jun 2011, 11:11 am »
SOLD!
