FS - EVS 100M Monoblocks (ICEPOWER) Asking $900
0 Members and 1 Guest are viewing this topic. Read 2002 times.
Sonny
« on: 13 Jun 2011, 08:19 pm »
Sadly, I am off loading these wonderful AMPS from EVS (RIC SCHULTZ) using the ICEPOWER using 200ASC modules.  I am now going to CLASS A (PASS X250) and need to fund the purchase.  Mine has the upgraded Jensen Capacitors and XLR balance and single ended inputs.
I am the original owners and paid $1200 for these.
Asking $900
Here's what Ric says:
the EVS100S mono amplifier uses the 200ASC modules (100 watts a channel into 8 ohms) in true dual mono configuration including separate power cords for each channel and the modules separated by three inches. Therefore, having separate mono blocks will not sound better unless you can significantly shorten the speaker wires.
The two supplied power cords are 14 gauge shielded Volex cords...very good.  Standard input jacks are OFC Soundconnections and the output connections are our exclusive binding post bypasses (we run the output wires through holes underneath the binding posts to the outside of the amp, tin the end of the wire, wrap it around the outside of the binding post and solder it to itself....this way the binding post is used only as a clamp and does not give any coloration to the sound....this type of wire to spade/wire clamp system will give better sound than any binding post there is). The wiring is state of the art and the AC wires are only 2 inches long and the output wires are only 4 inches long.  The amp is 16 inches wide, 8 inches deep and 3 inches tall.  It weighs a little under 6 lbs.  EAR feet are standard.
Sonny
Re: FS - EVS 100M Monoblocks (ICEPOWER) Asking $900
« Reply #1 on: 19 Jun 2011, 04:07 pm »
Happy Father's Day and get yourself a tweaked out switching by the "famed" Ric Schultz of Electronic Visionary Systems!
 :thumb:
Sonny
« Reply #2 on: 11 Aug 2011, 09:05 pm »
bump! :scratch:
