0 Members and 1 Guest are viewing this topic. Read 4105 times.
if you want information on tubes then i recommend http://www.ramlabs-musicreference.com/. as far as SET's go they are big in the mids, truncated in the bass and highs.r.
Anyone have a short wiki on tubes?I know about damping factor, and it appears tubes lack in that area, but that can't be the case for all tube amps.I hear some tube amps do not have any feedback at all, and are pure class A .... who make such amps? So, drop some knowledge on me.... Thanks.
What speakers are you using? You'd mentioned damping factor, and I find that speakers not only differ in terms of how much power they need but also in terms of the damping factor of the amp involved. A poor damping factor match can lead to speakers either being overdamped (constrained bass response) or underdamped (bass is a big boomy and not as well controlled). In my amp journey I have had problems with both overdamping and underdamping. Synergy, synergy, synergy.
Actually some good info in Wiki, although not really short.Damping factor is not "lacking" per say, but almost always lower with tube amps, specifically tube amps with no Global Negative Feedback. Single Ended amps, whether single ended triodes (SET: 300b, 2A3, 45, et al) or single ended pentodes (EL34, KT88, 6550, et al) often have no GNF. So with certain speakers an amp with a high DF would be "lacking" as in not a good match.As others have mentioned, a SET amp is pretty much the purest amplifier in that it's almost always class A (i.e.: Tubes run with the throttle wide open all the time) and usually low power, but not necessarily the best (I think they are, but that's just me). SET amps are usually the most limiting in that you really need to create the system around them more than other topologies. There are hundreds of ways to make great sound; SET, PP tubes, SS, in all sorts of configurations. It depends a lot on the speakers and the rest of the system.
I have been doing some searching regarding tube info, finding allot, but it's pretty drawn out, I guess I am looking for cliff notes.I am just looking for short explanations of things, like, the sound of certain model tubes (in general).One thing I know, I love a strong, tight bottom end, that is why I primarily use a digital amp, and even though the one I have is said to have a "tube like" mid/highs, I am looking for something better.I know about damping factor, and it appears tubes lack in that area, but that can't be the case for all tube amps.Looks like the primary choice in tube amps is SET, because they have less distortion (so I understand), but what is the advantage of tube amps that can switch between triode and ultralinear?I hear some tube amps do not have any feedback at all, and are pure class A .... who make such amps? All I really know about pure class A amps is that they do not have "cross over distortion", which I am not sure what that really sounds like.... I know one thing, when something does not sound right, it does not sound right.... listening fatigue is definitely an issue... So, drop some knowledge on me.... Thanks.
