cd label maker
0 Members and 1 Guest are viewing this topic. Read 939 times.
cd label maker
« on: 12 Jun 2011, 01:56 pm »
Looking for a free and easy way to make a label for cd cases.
Anyone know of a program that will allow you to enter some text and format it to the correct size for the front and back of a cd case?
thanks,
Rich
vinyl_guy
Re: cd label maker
« Reply #1 on: 12 Jun 2011, 02:17 pm »
Rich,
It's not free, but this is what I use. Works great and easy to use. http://www.surething.com/st/
Office Depot/Staples carry a CD/DVD labeling kit that includes a labeling program plus blank labels, inserts and the tool to stick the labels on the CDs.
Here is a free program. I've never tried it so I don't know how and if it works. http://www.nchsoftware.com/cdlabeler/index.html?gclid=CLbB8PXGsKkCFSBrgwod9Uq6KA
Laura
marvda1
  • freelance reviewer: The Sound Advocate
Re: cd label maker
« Reply #2 on: 12 Jun 2011, 02:21 pm »
while surething is not free, it allows you to use other manufacturers labels so you can shop around for the best deal on labels.
decal
Re: cd label maker
« Reply #3 on: 12 Jun 2011, 04:15 pm »
Google is your best friend. :eyebrows:
Re: cd label maker
« Reply #4 on: 12 Jun 2011, 10:56 pm »
Thanks for the replies.  Not looking for necessarily the cd label but rather the jewel case label.
Yes I should have googled first but didn't want to submit myself with out cause and identity submission.  Found a label maker in the apps store for a buck, thats where i should have looked first.
Just looking for something formatted for a scissors cut, fold and insert.
Hell, I'll even hand write the titles in.   :D
